configure policy convergence-endpoint clear
configure policy convergence-endpoint clear ports [port_list | all]
Description
This command clears all existing Convergence End Point (CEP) connections per port.
Syntax Description
ports Specify ports to configure.
port_list Designates which ports to clear CEP connections from.
Default
N/A
The following example clears CEP connections from port 3:
# configure policy convergence-endpoint clear ports 3
This command was first available in ExtremeXOS 22.2.
Platform Availability
